ā2008-05-09
05:16 AM
ā2023-05-26
03:09 PM
Rubia Torres
ā2008-05-09 04:43 PM
ā2008-05-09 06:12 PM
ā2008-05-09 07:12 PM
Erika wrote:The trouble is AC's 3D DWG is not so great. All triangulated and stuff. Some renderers won't show this but they generally look pretty bad.
Another option would be saving a 3D DWG. There are free viewers for that too. The model file size is much smaller as it loses all its smart bimness.
ā2008-05-09 08:43 PM
ā2008-05-09 09:25 PM
Chris wrote:Chris, I use Sketchup all the time and I was wondering if you set the option in the import menu to 'Merge coplanar faces'. This seems to take most of the lines out for me. I still go in and explode the model and then apply some textures and explode some walls if I want to clean them up some more. eg. there still seem to be line generated at the top of windows.
Sketchup - I've imported .3ds but the surfaces have lines all over them. Using the google earth connector, I have exported models to 3d warehouse, but run up against the 10mb limit (is there a way to just save the model to the hard drive without uploading? I didn't see one) The models are Ok but the textures look far worse in sketchup than AC and they have no edges which looks a little odd and I can't use the sketchup sketchy styles.
ā2008-05-09 09:54 PM
ā2008-05-10 01:57 AM
Gerald wrote:THANK YOU! The merge coplaner surfaces did it. MUCH better. File size is a little big - this a smallish house and it's 8.6mb - but will be manageble. Sketchup may still be too complicated (hard to imagine, but true) for less technical clients, but it will work for some and will certainly work for other professionals involved in a project.Chris wrote:Chris, I use Sketchup all the time and I was wondering if you set the option in the import menu to 'Merge coplanar faces'. This seems to take most of the lines out for me. I still go in and explode the model and then apply some textures and explode some walls if I want to clean them up some more. eg. there still seem to be line generated at the top of windows.
I then same some preset views for the client if they are not very computer literate. As far as project size goes I have found that SketchUp files compress pretty good but if your file is pretty complex the model can get too large to navigate around with (>30mb or so) and you may have to chop the model into pieces or take out some of the complex elements. I use an FTP to upload files to if they are larger than 10mb compressed.
ā2008-05-12 10:18 PM
ā2008-05-14 10:41 PM
