Visualization
top view with shadows?
how can i do? thanks
5 REPLIES 5
Dwight
It is true that you can't do this with one keystroke, but you can plan for it.
By turning off the roof/ceiling layers and making a top view, either through an internal engine analytical view, where shadow edges can be captured as lines or a rendering where the shadows will be cast as in a perspective, you get your effect.
One might think that the 3D cubic marquee could somehow come into play on this but I can't figure it out.
Dwight Atkinson
You must copy shadow from 3D Window, than put this on your roof plan:
Use internal engine, and take angle from top view, and copy with marquee tool jus shadow, and put this on your floor plan.
One tip:
Make extra layer for shadow. You can change egily color or something like that.
David Pacifico
I had it working, earlier. Maybe it was a beta.
A solution might be to use a horizontal cutting plane.
in AC10 check View/Elements in 3D view/3D Cutting Planes
Set a cutting plane, Then goto View/Elements in 3D view/3D Cutaway
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Dwight
Krikey.
Old ways, best ways, eh?
forgot all about that. ITs the thing, all right!
Dwight Atkinson
David Pacifico
We are showing our age when we pull out the cutting plane trick.
It's a trick!!
David Pacifico, RA
