__archiben
use of the lightworks 'floorboard' shader = reflectance bug?
dwight / anybody . . .
i've been trying with very little sucess to use the 'floorboard' lightworks shader. whatever i seem to do it renders with a very high reflectance resulting in an almost all white/glare render.
i've even started with the basic timber materials (which renders ok) and then simply switched the shader to floorboard: still loads of reflectance/glare . . .
has anybody had any luck using 'floorboard'?
cheers
~/archiben
b e n _ f r o s t
1 Reply 1
Dwight
I opened up Teak in the LWA/Architectural/Construction...
and you could do one of several things - the ambient, diffuse and specular seem a little high, say by twice.
especially the specular gives you glare
put a little amplitude into it.
I haven't gone thru this one, yet.
Dwight Atkinson
