Visualization
virtual memory too low when rendering
when i'm rendering in lightworks especially my final renderings i get an error message " virtual memory too low" any sugesstions as to how i can resolve that?
athlon xp2600, 768 mb ddr 333, 2 80 gig hd, 128 nvdia geforce 4000 graphics card
6 REPLIES 6
Ben Odonnell
You could do one of two things.
1.Free up some space on your hard drive, that works as the virtual memory drive.
2. Change to another, lager, partition.
THE.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
Set the minimum virtual memory to three times your physical RAM.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Where is the setting menu that would allow me to change the virtual memory? Is it in archicad or in windows?
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
Ben Odonnell
Scott ,
You will find it by Right clicking "My Computer" (But it's really yours )Properties, then by taking the "Advanced" tab -----> "Performances"-->"Settings"---->"Advanced"
You will finally find the virtual memory settings at the bottom of the dialog.
HTH
Cheers.
Ben
Ben O'Donnell
stefan
Is this still necessary for PC's with very much RAM? I have 2 GB and don't want to throw 6 GB of the Hard disk away...
Archicad-user since 1998
my Archicad Book
Djordje
I would "throw" 20GB away if that made a difference between having the rendering or not.
Djordje
HP Omen
