Make sure you have both end points of the straight edge of the element inside the marquee. If one of the end points is outside then it will not move and you will get elements on angles.
Use the irregular shaped marquee if needed.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
