2008-02-04 03:04 PM
2008-02-05 07:39 PM
Laura wrote:.....and Marx Brother
Our Publishing Sets are grouped by purposeandoutput device, for example:
2008-02-05 07:47 PM
Stress wrote:We have four printers: Chico, Zeppo, Groucho, and Harpo. Somebody had a sense of humor...Laura wrote:.....and Marx Brother
2008-02-05 07:58 PM
Laura wrote:My all-in-one is know as "the antichrist".
2008-03-11 11:49 AM
2008-03-11 10:58 PM
Keith wrote:Right.
So you don't have to make one set of layouts for publishing to one printer, and another set for publishing to another. The contents of one set can go to different printers for different layout sizes, as appropriate.
Keith wrote:No - it's not an error. The idea is that you can set them individually if you have different sizes within the set. Imagine you have a set with mnostly A2 layouts, except for a couple of A4 layouts for your schedules. Setting them individually allows you to include them all in one publisher set.
Oddly, though, although you can set the printer for each layout, you can only set one 'preset' for the whole set. Is that an error?
Keith wrote:Yes, I fear the good programmers at GS may have taken a bit of a shortcut here. As part of the setup process, it doesn't actually print, and should just read OK.
And when you set the printer, the confirm button is marked 'PRINT' rather than 'OK', which is a bit confusing.
2008-03-12 01:14 PM
Link wrote:Run that past me again?
If however they are all one size, then you can just set the properties for the folder in which they all reside, and it will set the properties for all those layouts. Easy!
2008-03-12 02:33 PM
2008-03-13 12:02 AM
2008-03-13 10:32 AM
