2005-08-28 12:20 AM
2005-08-28 11:11 AM
2005-08-28 11:45 AM
2005-08-28 12:39 PM
2005-08-28 04:37 PM
James wrote:US Tech Support seems to think that bugs only occur when the program does not act as the programmer intended. If the programmer did not intend for columns to look the same in section as in plan, it's not a bug.... right??
I call it a bug too, and I have reported it as such. I was told, it's not standard to cut sections through columns. It's true, but it's still a straightforward VB-consistency issue. I have wanted to cut through a concrete/maconry pier in order to start a detail.
The other thing is that the 'defined' use of the tool is only part of it. You can use all the tools to make things other than the building elements in their names. If the section worked right, you could make a chimney from a column. Columns don't usually require sections, but something made from a column might.
Bonus column consistency gripe: Their plans aren't stretchable.
2005-08-28 06:10 PM
2005-08-28 07:01 PM
2005-08-28 10:11 PM
2010-03-17 05:58 PM
2010-03-17 10:27 PM
