There seem to be a different embedded scale/unit factor in the FBX files exported from Archicad 27 compared to fbx files exported from AC24. It is now in meters as far as I can tell. Would it be possible to include a way for the user to manually set the unit during export, as an improvement for future releases of the FBX export plugin? The reason for this wish is to avoid both extra work and extra sources of errors when importing into other programs like 3dsMax.
When exporting from Archicad 24 this problem doesn't occur.
Export from Archicad 27:
![KarlWir_n_0-1704725464826.png KarlWir_n_0-1704725464826.png](/t5/image/serverpage/image-id/51675i257D8AF231EE3434/image-dimensions/769x322?v=v2)
Export from Archicad 24:
![KarlWir_n_1-1704725795790.png KarlWir_n_1-1704725795790.png](/t5/image/serverpage/image-id/51676i5396F3ED89FB2799/image-dimensions/770x270?v=v2)
