2010-12-01 06:53 AM
2014-03-25 02:14 PM
2014-03-31 03:12 AM
2016-01-20 06:26 AM
2016-01-25 01:20 AM
2016-02-10 04:04 PM
2019-12-15 10:53 AM
2022-07-05 10:32 AM
I Think this issue should really be fixed soon. I find requests for this from 2004 already. So in almost 20 years this issue i still a problem.\
In our office this issue is now a hot toppic as wel. a sollution was always to work around this to work with anly a main model and a module workspace file wich we linked to the mainmodel. This has the problem that this is extremely slow. We work a lot in larger project with a lot of repetion so we would like to work with this hotlinks. The problem we get in to when working with multiple hotlink files is that you have to transfer atributes between all the files. This has an high potiontial for mistakes and errors.
Really for a bimsoftware this should be solved ASAP, either in the software itself, plugin or something else that's for instance linked to the atribute file that you can make. This could be the quick fix, but in the end I think it should be part of the core software.
Please solve this.
2022-07-05 10:33 AM
here the link to an older post
