Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wishes
SOLVED!
Limit gs_picture_name VALUES list
It would be great to be able to filter the list of loaded image file names. The Carpet object doesn't really need access to all the UI images šŸ˜€
James Murray
Archicad 27 ā€¢ Rill Architects ā€¢ macOS ā€¢ OnLand.info
1 ACCEPTED SOLUTION
Solution
runxel
Legend
This is somewhat possible, but it need two things as a preparation:
The object must be scripted in the right way (APPLICATION_QUERY ("LIBRARY_MANAGER", "USER_IMAGE_FILES", image_files_list)).
AND secondly all files that are for usage in the UI / somewhere else need to be put in one of the following folders: [TImg]*, [BImg]*, [UImg]*, or [HImg]*.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
2 REPLIES 2
Solution
runxel
Legend
TIL. Thanks runxel.
James Murray
