2020-08-19 02:04 PM
2020-08-24 01:46 PM
2020-08-24 02:00 PM
2020-08-24 02:31 PM
2020-08-24 05:01 PM
Gergely wrote:I mean using the GO to change the BM original attribute definition from Visible Lines to Merged Lines.
I'm not sure if the fine-tuning should be GO based though. (don't even know if that part would technically be feasible - GO can only remove-replace attributes, not really capable of drawing lines back if they were not there in the first place.
2020-08-25 12:08 PM
2020-08-26 05:00 AM
2020-08-26 10:00 AM
2020-08-26 11:37 AM
Marc wrote:
But then, I have a condition In the design where the SEOR wants a fully integral column set and shear wall. I select the two columns and the wall and check a box marked Merge Element Coplaner Material within the elements Info box.
DGsketcher wrote:That's why I suggested the GO for Line/Surface Merging to complement Gergely's solution. You could then create a GO Rule to select only the specific elements and apply them the correct Line/Surface Merging.
The only problem I see with it is basic render / 3D document type images where you might want to merge the surface as an option for presentation purposes but still need to show the break lines for technical illustration.
2020-08-27 04:20 AM
2020-08-27 11:02 AM
