2024-05-16 01:53 PM
Can we make this tool clean up properly as it doesn't at the moment. Also if you happen to create this wall as a continuous "U" shape and install a window or door in one of the opposing legs, the opening also appears on the opposite wall as its part of the same structure which is silly
thanks
2024-05-16 03:43 PM
Post a picture.
Generally the Poly Walls clean up pretty pretty well – but you need to know how to handle them.
Also my advice is to always draw a normal wall first, and THEN convert it! It retains the blue reference line! If you do not do this it is a bit of a gamble.
And U-shapes are out of reach. Don't do that.
