2019-06-25 03:17 PM
if GLOB_SCRIPT_TYPE = 2 or GLOB_SCRIPT_TYPE = 3 then _nComponents = 0 dim _componentTypes[] n = REQUEST{2} ("Profile_components", myProfileIdx, _nComponents, _componentTypes) n2 = REQUEST ("Profile_default_boundingbox", myProfileIdx, _xmin, _ymin, _xmax, _ymax) if n then dim _bShowPart[] _needRequestDetails = 0 for _i = 1 to _nComponents _bShowPart[_i] = 1 if GLOB_STRUCTURE_DISPLAY = 1 AND _componentTypes[_i] <> COMPTYPE_CORE then _bShowPart[_i] = 0 ! GLOB_STRUCTURE_DISPLAY: 0 – entire structure, 1 – core only, 2 – without finishes if GLOB_STRUCTURE_DISPLAY = 2 AND _componentTypes[_i] = COMPTYPE_FINISH then _bShowPart[_i] = 0 if _bShowPart[_i] then _needRequestDetails = 1 next _i if _needRequestDetails then dim _profileGeometryRawData[] n = REQUEST ("Profile_default_geometry", myProfileIdx, _profileGeometryRawData) ! n1, n2, ..., nn, x11, y11,s11 dim _contStartPoints[] dim _contEndPoints[] _contStartPoints[1] = _nComponents + 1 for _i = 2 to _nComponents _contStartPoints[_i] = _contStartPoints[_i - 1] + _profileGeometryRawData[_i - 1] * 5 _contEndPoints[_i-1] = _contStartPoints[_i] - 1 next _i _contEndPoints[_nComponents] = vardim1(_profileGeometryRawData) endif endif endif
if n then for _iComp = 1 to _nComponents if _bShowPart[_iComp] then dim _currSurfaces[] n = REQUEST{3} ("Profile_component_info", myProfileIdx, _iComp, "gs_profile_comp_surfaces", _currSurfaces) _bmat = 1 _surface = 1 _pen = 1 n = REQUEST{3} ("Profile_component_info", myProfileIdx, _iComp, "gs_profile_bmat", _bmat) n = REQUEST{3} ("Profile_component_info", myProfileIdx, _iComp, "gs_profile_surface", _surface) n = REQUEST{3} ("Profile_component_info", myProfileIdx, _iComp, "gs_profile_outlinepen", _pen) building_material _bmat pen _pen put (_contEndPoints[_iComp] - _contStartPoints[_iComp] + 1) / 5, !number of contour control points 7, ! number of route points - fixed in this example 1 + 2 + 16 + 32 ! mask _surfIdx = 1 for _i = _contStartPoints[_iComp] to _contEndPoints[_iComp] step 5 put _profileGeometryRawData[_i], _profileGeometryRawData[_i + 1], _profileGeometryRawData[_i + 2] + _profileGeometryRawData[_i + 3] + _profileGeometryRawData[_i + 4], _currSurfaces[_surfIdx] _surfIdx = _surfIdx + 1 next _i ! put points for route put 0, 0, -1, 90, 0, 0, 0, 90, 0, 0, 1, 90, 1, 0, 1, 90, 1, 0, 2, 180, 1, 1, 2, 180, 1, 1, 3, 180 tube{2} _surface, _surface, _surface, get (NSP) endif next _iComp endif
tube{2} _surface, _surface, _surface, get (NSP) !!! just the root !!!! then some type of new command to use the profile parameter with a single line...
