Wishes
Save rendering settings among ALL projects
vfrontiers
Seems TEDIOUS to go setup a rendering SCENE for one project, then have to EXPORT and IMPORT into another project..
Would be nice if this were a more global default? Maybe part of the LOADED LIBRARIES...
I also feel the same about SCHEDULES...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
3 REPLIES 3
I think you do these things in Template Files, no? Whenever there is a Library or Rendering Scene or Schedule Settings you wish in all your Projects (actually this applies to any settings that can be exported/imported), you should import these settings into your Template File and then all your later Projects will have that setting.
Would that be a solution for you?
vfrontiers
True and good... but there's also BACK TRACKING to projects PREVIOUS to setting my killer rendering scheme...
Duane
Visual Frontiers
Yes, it needs to be done as well for ongoing projects. Can be a bit time-consuming if there are many. So for those I would do the import only if and when it is actually needed.
