Wishes
default title linked to layout sheet
It would be nice if one could specify what title type to use (as a default) for each layout sheet or better yet for each subset. Often times I import drawings and find myself having to go to the drawing settings and selecting a different title type. I know its small, but sometimes its the small things that make your life easier.
3 REPLIES 3
I would like to expand this wish to allow subsets to also have a default master layout assigned to them.
Link
You can right click on any (non-default) title or master and select 'Set as Default'.
Defaults will be used for any new drawings/layouts and are easily recognized by their dog-eared icons.
Link.
Wow, I know this is an old post, but I wish I had discovered this earlier. I did not know you could set a default master for all new sheets. This will save me precious minutes everyday.
Now I can use those saved minutes to froth the milk for my coffee.
