Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wishes
list recent clicked views
alemanda
It would be very nice to have the possibility to have a list of the last recent used views.
In big projects often you jump from a view to another to another one ...
when they are well organized by disciplines in the navigator you lose a lot of time searching for the views you use more frequently ...
It would help a lot.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
3 REPLIES 3
Erwin Edel
On windows CTRL + TAB will allways switch between active windows in a program. You can also see which windows are open in the Window menu.
Sometimes I use Trace Reference to keep toggling between two views (there is a button to switch the trace around).
I have F2 as hotkey for plan view, CTRL F5 to show all in 3D window.
Maybe these things can help?
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
alemanda
I already know what you mentioned. Unfortunately there more views I have to browse ... Thanks
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
sinceV6
Hi.
The easiest way is to create or customize a toolbar (or even create a single menu button) then use the "Recent ..." lists (or the "List of opened ...") menu items that appear in the Work Enviroment editor (use the "all commands in alphabetical order" to find them easier) and add them to that button.
Hope that makes sense.
Best regards.
