elevations/sections can show surface images, would be amazing to be able to do the same for 3d documents (probably an even more useful uncut appearance than for elevations!)
I think this is essential, also the addition of soft shadows already present in section/elevation tool (something similar to ambient occlusion, I think, as all 3d modelling software has from decades),
at least to have an uniform output, in fact now the elevations/sections that are laid out in the same sheet, seem to come from 2 different software
I've moved to 'on hold' as we'd need to develop a base technology to distort textures correctly in perspective views (which are possible in 3D Documents).
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
