Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Detailer Library USA
In the older version of USA libraries, there is a section for 2D details.
This is unique to the USA library, but now we have 'Global' libraries, there is no library pack for these USA details.
Could a library pack of these details please be created?
8 Comments
Apparently there is a detail library available with the USA Archicad installation.
It can be found in ... Archicad 28 > Archicad Legacy Objects
And is called ... Archicad Legacy Objects USA.lcf
As far as I know it is only available to those installing the USA version of the software.
It could easily be created as a library package available to all users (I understand that the objects are USA based and imperial dimensions).
I will leave it to the powers that be to decide if this wish is to be closed or not.
At least we know where to find the old library now.
Jere
Agreed 100%. I wouldn't relegate it to a legacy library. I'm sure some of these objects are useful for the global market.
Csaba Nemeth
Dear All,
Legacy contents are available here for all relevant languages: Downloads – Graphisoft
Regards,
Csaba
Matt G
We too have been updating with the attempt to only use current library parts.
We use a lot of these detail items in our sections however so we are also stuck with having to load old libraries - which I was trying to get away from.
I understand this for ‘a one’ off item but when it’s full of useful things I’d second that it should be included please.
Matt
zoli79
I loaded the legacy objects and I have some problems:
1. If this is a LEGACY object, why doesn't DET_Stud have the same GUID as DET_Stud 27? I have 429 instances of that object in our template, 95% in hundreds of details. I need to go to every single detail and manually change them one by one. Injecting properties doesn't work, since they have different settings + the orientation is different, so after injecting, the stud moves to a different location. This is very frustrating.
2. Why is this legacy? What does Graphisoft offer that is better and more up to standard? I don't like loading legacy libpacks to a template.
3. How is it better to load this Legacy libpack than creating a Detailer package with the 27 objects used? The term "legacy" doesn't sound like it's going to be cared for in the future, so how is it better than the 27 objects? All I see is days of work transferring to something that is already suggested to be obsolete.
"Fixing" 700+ details is going to be fun...
Graphisoft should at least offer smarter search and listing options across full project (details, sections, layouts etc.) I have no idea where objects are if they aren't in the model space. (Is there a wish for that?)
None of the 28 library packs are backwards compatible with 27.
In other words 27 objects will not migrate to 28.
I don't use it, but I assume even the legacy objects pack is a 'new' library with new GUIDs.
It is the same old objects but saved with new GUIDs.
I guess it is 'Legacy' because Graphisoft no longer want to maintain these objects and want you to use the new library objects?
I really don't know.
If you are opening an old file, just keep using the old libraries.
If you are opening a new file based on a 28 template, then use only the new global libraries.
And if you really need these particular library parts, then load the legacy global library pack, and don't worry about the fact they have called it 'Legacy".
JEichhorn
I'm late to the party here, as I'm switching to Global Libraries now with AC29.  I'm curious if anyone has found a nice substitute for the DET_Stud library part rather than bringing legacy parts into the project?
Thanks!
Jeff
zoli79
I haven't found any replacements for the stuff in the legacy library. (Although with a trick I was able to solve migration from 27 to the "new" legacy objects.) There are a lot of essential stuff in the Legacy libpack apart from detailers: NCS Drawing title, Section part marker_NCS, Simple Title. These are US standards, and I haven't found real substitutes in the International libraries. If it were only studs and similar items, I would save the objects and load to the other custom objects, but since there are more essential ones still in the legacy folder, it seems that we have to load it anyways...
It's a shame, because it adds another tab to the MVO panel. And also the fact that US industry standards are lumped in a "legacy" folder does not send out a good message.
Status
Open
with 8/200 Votes 25%
Wish details
