Graphic overrides would be much better if we could apply a color range for some properties, parameters or simply data.
One use case is in urbanism where for example I want to show height of the building scheme (either in 3D or 2D site drawing).
As for now, We have to create multiple rules for each possible value.
With color range we could set eg. minimum and maximum value and their representative colours. Or just simply say to assign different colour for a different value for properties with possibility to change he colour if needed.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
