Master/Default font override
Yvonne
It would be amazing if its possible to change all the fonts in a project to 1 font. Like a master font or an override of fonts...
See original post ... https://community.graphisoft.com/t5/Document-Visualize-forum/Change-default-font-in-project/td-p/367...
6 Comments
Guru
Rather than a master font or overrides, I think Text Styles would be better. Basically making favourites linked to their applied object, which in this case is text.
Erwin Edel
We've basically defaulted to arial out of ease ages ago, but this is a great idea!
rakurs
Text styles would be great.
As an addition, for example, in MS Word (and probably tons of other software) you can set in the general document properties what is your "body text" font and your "headings" font - and then, in individual styles, you can refer to that "tag" so you don't have to change multiple styles just because you want your (multiple different style) headings to look differently.
James B
Status changed to: On hold
Thanks for the suggestion and feedback.
When we introduced graphical Favourites, we gave access to the text favourites via dimensions, schedule text, and directly in the text editor for example.
But understand the benefit of having text styles centrally controlled for consistency of documentation.
I've moved this to 'on hold' for now.
Tanja Be
A suggestion would be to change the font in a Work Environment or Project Preferences menu, the same way you choose your dimension unit per Project.
James B
Status changed to: Submitted
Status
Submitted
with 52 Votes
Wish details
