More & better GRAPHIC OVERRIDE options
Leire Bilbao
The graphic overrides are awesome, but many times you need more. For example:
- override a part of a bigger object, but not the whole object (like a window, complex profile, wall, composite, stairs...).
- override surfaces in an elevation
- override the lines of a wall different depending on its surfaces for a wall finishes plan
- many criteria are "contains" and that gives you the wrong override with composites and materials
1 Comment
SimSmi1
Revit does this and its one of the only good things over ArchiCad. The ability to override or hide just a single line within larger elements would give the ability to tidy up messy junctions in plan and rogue lines on elevations.
Status
Upvoted
with 47 Votes
Wish details
Product
Labels
