More flexible design for Windows and Doors
Leire Bilbao
More options for design of windows. Infinite combinations of portions and openings.
If I want to have 3 sliders, with top hung window over and a bottom fixed transom and a sidelight, I should be able to do it.
No need for a million types of windows, just make the "variable" window FULLY variable so I can add as many parts I want with whatever openings I want.
15 Comments
Danmardan
Great point,
1 - we need windows for more specific frame like passivhaus standard windows: https://www.passivhausfenster.com/en/homeowners/products/smartwin
2 - we need conectivity for passivhaus and for wood or straw wall panels settings.
3 - working reveal settings in 3D supporting structure of the wall not only in 2D!
4 - in the shading setting we need more options:  shutter to insolation maybe
5 - frameless settings for fix + opening window
saggyhaggis
I should also add.
When changing a window to a different opening arrangment / type, all the previously defined properties of the opening are lost which is time consuming to rectify.
DOWA
@saggyhaggis
If you select the window or door on floorplan/section/3D... and then pick up it´s properties with the eyedropper tool (ALT), then go into it´s settings and CTRL+ALT (syringe tool) + click on an other window/door type. It will inherit the properties.
saggyhaggis
@DOWA Thanks for this nugget of information!
This is never mentioned in any presentations or discussions that I have seen.
ArchiProject
I suggest taking inspiration from Allplan's windows, where you first define the characteristics of the window, then you insert it into an opening of any shape and it adapts.
Status
Upvoted
with 151 Votes
Wish details
Product
Labels
