Section Marker - Move marker buble and arrow without changing section extent
Often the section marker buble and arrow clashes with labels, dimension or other documentation elements.
It would be great if we could re-position the Section Marker in each wiew without affecting the extent of the section!
Currently only the text component of the marker can move, which is quite silly.
- Nobody wants to move the text without the arrow.
- Nobody wants to move the text simmetrically (both ends of the marker)
- Nobody wants to move the text in every wiew where the marker is visible
Please fix this, since the current behaviour of the marker is ridiculous.
3 Comments
You can always add a 'linked' marker to any plan and then hide the original section in a layer that you can turn off.
This way you can have multiple linked markers in different positions on different plans (layers or storeys).
@Barry Kelly
That's true and I know it, but it is still a cumbersome workflow.
rakurs
It would be great if there were vertexes on the section / elevation line which would signify section boundary, while the line and marker could be placed anywhere, even before the boundary.
Status
Submitted
with 6 Votes
