Set symbol line for MEP route in MEP systems
Karel Landa
Why can not we set symbol line in MEP systems dialog window?
This is possible in MEP route settings but that leads to overriding MEP systems and thus leading to more errors in project.
2 Comments
s_p_b
I posted a stopgap solution, but this should be solved properly.
https://community.graphisoft.com/t5/Libraries-objects/MEP-Pipe-with-symbolic-linetype/m-p/702159/hig...
The MEP objects that use symbolic linetypes should ideally offer the option to flip the direction of the line when the route's direction is between 90 and 270 degrees, so that linestypes with text in them remain readable.
Karel Landa
It is also quite simple to set multiple GOs rules now that only axis can be shown but it is still weird.
Status
Submitted
with 12 Votes
