Symbolic view for complex profile walls
Complex profile walls can have many fills stacked above one another or even varying thicknesses to the wall at different heights - unlike a standard composite wall.
However in plan we don't have a "symbolic" floor plan display option.
We have to use the 'Projected' or 'Cut only' displays, which means we must rely on the actual 'Floor Plan Cut Plane' height to display those walls correctly.
This creates a problem when you want to display different heights of different walls or you have other elements that rely on the FPCP height.
Obviously because of the many varied fills and thicknesses, we would then need a way to nominate the default cutting plane height in the complex profile settings so we can get the correct (or desired) cut view of the complex profile.
This nominated height would be used as the 'Symbolic' cut of the wall.
So my wish is for a 'Symbolic' floor plan display view for complex profile walls.
16 Comments
NOW
event a simple half height floor. ( between Home Floor & Upper Floor ). that kind of floor editing for user is nitemare ......
3D Floor Cut is Perfect.
BUT 3D Floor Cut is USELESS....
IT LOCK ALL THE FLOOR PLAN FUNCTION..... user just View Only
Minh Nguyen
Hi Barry,
Thanks for sharing the wish and creating the pool!
I'm happy to say that this is a known wish in our database (please refer to it as #7211). I hope that our Product Management team will consider adopting this one in the future!
Thank you once again, and have a great day!
Best regards,
Minh
Thanks Minh.
I will keep an eye out for it.
cagarruta
Hello Minh, any news about this?
thanks
Minh won't be able to tell us anything about this, as he no longer works at Graphisoft.
All we can do is hope that it is indeed something that will be considered.
cagarruta
Thanks Barry
Just bumping this wish.
I'd really like it to get a few more likes. 😀
marco conti
Really usefull, not only for walls, but also for other instruments such as columns, beams, MEP, etc...
SeaGeoff
Ace
Bumping this wish. I would use CP walls a lot more often if this was available. I'm sure many other uses would as well.
No need to bump upvoted wishes. "Upvoted" means that the wish has already been submitted to the Product Team for evaluation.
Status
Submitted
with 96 Votes
Wish details
