Textbox customise background fill
scottjm
Mentor
I would love the ability to the be able to change the default background fill of a textbox to any fill.
The most common usage I have wanted it for is apply a 25% fill to a textbox.  The current workaround is to add a separate fill behind the textbox.
5 Comments
Yes, so we can have a semi transparent fill rather than solid or fully transparent.
JeffH
This is a must, graphisoft!
runxel
I support it but I found out that you can achieve it with a Graphic Override, @scottjm! No need for separate fills or other time consuming workarounds.
scottjm
Mentor
Omg! I’d never thought of that! Gonna give that a go. I guess that would be an all or nothing setting per GO, but I guess that’s better than nothing.
JeffH
It is all or nothing, but if you are using 27 or newer, you could create a option status for the ones you want to override, as that is available to adjust for text..So it would give you a hair more of a control.
Status
Open
with 23/200 Votes 8.695652173913%
Wish details
