region view on floorplan
Debraeve DIego
What would also be convenient in Archicad (and this is possible in Revit), is that you can draw a local “region view” in the floor plans where you can set the “floor plan cut plane settings” separately for this “region view”. (Useful for example if there are windows drawn at ceiling height that a normal cut plane of 150cm does not show).
12 Comments
I made a wish about complex profile walls having a symbolic representation.
https://community.graphisoft.com/t5/Wishlist/Symbolic-view-for-complex-profile-walls/idi-p/256277
It certainly would be nice and this is just another reason why we need it..
Karel Landa
Yes, that is a one more thing we need but the wish @Debraeve DIego is suggesting is also important.
As I said more for large scale projects where floor levels in one story are different but also for such cases where the windows is in different position (one of common situation is when there is a Window in stair middle landing and the wall may be modelled in upper story)
Status
Open
with 20/200 Votes 10%
