2023-11-17 01:25 PM - last edited on 2023-11-24 05:38 PM by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
2023-11-17
04:37 PM
2023-11-18
12:25 AM
Hello, I have issues launching the Ai Engine. The window shows me some errors and fails to launch.
Hopefully someone can provide me with some answers.
Kind regards!
Paul Spaltman
2023-11-17 04:39 PM
2023-11-17 04:55 PM
Thanks, it worked!
2023-11-17 07:17 PM
Can you please tell, where the sd_webui is located on your computer?
Kind regards,
Illés
2023-11-17 09:07 PM
I’ve tried installing the AI visualiser and just get an error in Terminal when I run the first command saying the process cannot proceed because of various errors.
2023-11-17 10:32 PM - edited 2023-11-17 10:33 PM
ERROR: python3-venv is not installed, aborting
After dragging run.sh it to the Terminal window and hit Enter, this message shows up in HomeBrew / Terminal.
I have moved the AI Visualizer folder from Add-ons into Archicad 27 folder > Add-ons > Extra.
And i have moved the sd.webui folder into Archicad 27 folder.
2023-11-18 11:58 AM
I've downloaded a nearly 20GB compressed package, but I'm struggling to extract it. I've tried several pieces of software like 7-zip, etc., and each time it reports dozens of errors. Has anyone experienced a similar issue? I'm using Windows 11.
2023-11-18 01:11 PM
I unzipped it with WinRar without any issues. But it's a ton of data, so it's tricky. Good luck!
2023-11-18 01:13 PM
You should extract the AI visualizer to the AC27 folder and sd.webui to C:
Subject | Likes |
1 | |
1 | |
1 |
