This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-17 01:25 PM - last edited on 2023-11-24 05:38 PM by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
2023-11-20 12:53 PM
Well, our C drive is reserved for system files and it´s not a very big drive, so I can´t test this 😅 I guess there must a way to install sd.webui somewhere else tinkering with the files...
2023-11-20 03:26 PM
Currently the files need to reside under C: otherwise the Add-on, unfortunately won't be able to use its resources.
2023-11-20
04:35 PM
2023-11-22
02:28 AM
I have downloaded and followed the installation steps for windows but the AI pallette dosent show on archicad 26.
Any idea why?
regards
Joel
p.s. i checked now and on add-on manager says "the file is an outdated add-on that cannot be used with this archicad version"
2023-11-20 04:51 PM
I have the same problem with AC26.
2023-11-20 04:52 PM
This addon is dedicated to AC 27.
2023-11-20 05:29 PM
I have installed AC 27, installed the add-on but now says tha the AI server is not available or the add-on could not connect to it. What is supposed to be the server address?
2023-11-20 05:38 PM
I got the same messaeg and the cmd window stated memory issues (Cuda). I updated the graphic card drivers and got it to work once...not after that and it's horribly slow on my laptop with 6GB RTX A3000. Will not spend more time with this probably cool addon until it plays more nicely with me :).
2023-11-20 10:28 PM
I have the same error, even waiting a lot...
2023-11-20 11:03 PM
Hi Illes, Ive tried differente configurations, models and image sizes. Server looks fine, but after some time running, archicad show an image generation failed message, but in the the server windows, it continues to 100% and shows no errors at all. But at the end no image is generated...
thanks, all the Best
Marco Milazzo
2023-11-21 08:26 AM
I get this error too. I’ve got a very very basic model that seems to generate an image after about 5-10 mins but a slightly more complex model just creates that same error. Sometimes the server window says 75% progress and other times 100%.
