This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
‎2023-11-17 01:25 PM - last edited on ‎2023-11-24 05:38 PM by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
‎2023-11-21 07:35 PM
Thank you for reporting this. It is likely to happen because of the previous version of the installation guide had a breakline in the command. It is now fixed, please try with the new PDF guide.
‎2023-11-21 07:47 PM
Could you please provide a screenshot of the command prompt content?
‎2023-11-21 07:54 PM
Could you please provide a screenshot of the command prompt content? This may be for several different reasons and a screenshot would be helpful to narrow it down.
‎2023-11-21 07:57 PM
Dear Peter Dobrosi,
Could you kindly elaborate what do you mean by "Already renamed them as Hungarian version", as this may affect the installation?
Regarding the Radeon card, AMD cards have an unfortunate limitation for SDXL. This is unfortunately not yet reflected in the System Requirements; we will update the PDF soon. Thank you for reporting this.
‎2023-11-21 07:59 PM
The server address is by default the localhost address provided in the installation guide. It also appears in the command prompt and you can check if it is different from the default for any reason. In that case you need to use the one that appears in the command prompt after the server is successfully started.
‎2023-11-21 08:01 PM
Thank you for the report. Unfortunately even though your card may be otherwise quite powerful, it simply lacks 2 more GB memory to reach the minimum requirements for VRAM.
‎2023-11-21 08:04 PM
Can you share a screenshot of the command prompt that appears when generation fails?
‎2023-11-21 08:06 PM
Model complexity has no effect on the generation in terms of generation time or performance only as an input for the AI Engine to add your prompt to. This may be for another reason. If you can provide a screenshot of the command prompt, we may see something that tells us why it fails on delivering the end result.
‎2023-11-21 08:17 PM
Hi Illes, i saw now that the minimum required Vram is 8Gbytes, and i have only 4Gb..
Thanks
Best
Marco Milazzo
‎2023-11-21 11:05 PM
Illes...know it works. Thanks 🙂
