Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI Visualizer Technical questions
Illes Papp
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
Illés Papp
GRAPHISOFT Senior Product Manager
135 REPLIES 135
Does your computer meet the hardware requirements?
Does the video card have enough VRAM?
Do you have an Nvidia or AMD GPU?
I have restartet the PC and it worked. Thanks
i had asked this same question in January.  after trying multiple times to install it and get it to work.
MacBook Pro 16-inch, 2023, with Apple M2 Pro chip.
i don't know where to find the VRAM, NVIDIA or AMD GPU information.
Your M2 Pro chip should be more than adequate. It’s a system on a chip so you won’t find the details you mention.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
thanks, Lee.  i still don't understand why I could never load the AI Visualizer.  i will update to AC28 soon, and will try again then.
In AC 28 you will need a collaboration subscription or EDU license.
