This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-17 01:25 PM - last edited on 2023-11-24 05:38 PM by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
2024-03-01 04:31 PM - edited 2024-03-01 04:32 PM
Keep in mind I have 16gb of ram. Additionally lowVRAM gets me a different error message as noted above:
" RuntimeError: "upsample_nearest2d_channels_last" not implemented for 'Half' "
2024-03-04 04:22 PM
Hi kylevfa,
Thank you for the answer.
The lowVRAM mode should work fine with your setup. Please contact your local support we will need to investigate this, and share the full content of the Terminal window if possible.
Kind regards,
Technical Support Engineer
2024-03-12 03:35 PM
Hi Norbert,
A colleague of mine facing the very same issue contacted support and they stated they do not have the knowledge to comment on the AI Visualizer. Is there any additional support you could provide for us to try to get this working? Even if it's just the low VRAM mode? I've attached the content of the terminal window below.
Thanks
2024-03-14 02:59 PM
Hi kylevfa,
Thanks for the screenshots.
Which macOS version are you using?
Please run this command in Terminal and send us the output:
/opt/homebrew/opt/python@3.10/bin/python3.10 -m pip list
Thank you,
2024-03-14 03:06 PM
2024-03-18 03:46 PM
Hi kylevfa,
Thank you. Can you please update your macOS Monterey to the latest build?
Kind regards,
2024-04-13 12:14 PM - edited 2024-04-13 05:28 PM
Hi everyone, @Illes Papp
I read here below that Windows users, should extract the sd.webui folder directly into C:/ and not copy/paste it from another directory. But the file AI_Visualizer_Add-on-27-INT-install_package-WIN.zip contains both, the Add-ons and the sd.webui folders.
My question is: how do you extract via WinRAR one item (the sd.webui folder in this case) to a specific directory and the other item (Add-ons) to another directory?
Also, I already have an Add-ons folder in my Archicad folder (it contains Goodies, Extras, Import-Export etc). How do you install the AI Add-on without overwriting the existing folder?
Thank you
2024-04-15 10:35 AM
Hi Ion,
Please don't use any 3rd party software to unpack the sd.webui folder to C:/ root. The Add-on folder can be extracted to C:/ root as well and then copy-pasted and merged with the existing Add-on folder of your Archicad 27.
Kind regards,
2024-04-15 08:04 PM - edited 2024-04-15 08:05 PM
Thank you
May I elaborate on your reply to those who might have the same questions as me:
After you download the .zip file, you right-click on it and hit "Extract All" (windows preinstalled feature, do not use 3rd party software) to C:/
Leave the sd.webui folder there.
Now, if you already have installed Extras in the past its directory should most probably be C:\Program Files\GRAPHISOFT\Archicad 27\Add-Ons\Extras
In this case, cut/paste the AI Visualizer folder from C:\Add-Ons\Extras to the directory above so that now you will have C:\Program Files\GRAPHISOFT\Archicad 27\Add-Ons\Extras\AI Visualizer.
Anyway, I managed to get a few results. Not bad at all for a composition of four slabs.
a month ago - last edited 3 weeks ago by Laszlo Nagy
My AI engine doesn't load on AC 27. Anyone knows why?
