2023-11-17 04:44 PM - last edited on 2023-11-21 11:34 PM by Laszlo Nagy
I, Have Downloaded the AI Virtualizer, dragged it in to the add-onn folder but receive an AI server not available Error. What am i doing wrong?
2023-11-20 07:45 AM
I am facing the same error. You found any solution?
2023-11-20 08:41 AM
Hi Vikass,
No i have a Macbook pro M1 can not test it on windows..
2023-11-20 10:20 AM - last edited on 2023-11-21 11:36 PM by Laszlo Nagy
I had the same problem.
You have to drag run.sh file into terminal.
Then it will find the server.
2023-11-20 10:24 AM
What to be done for windows?
2023-11-20 12:21 PM
For all having problem on Mac, I noticed that if you close Terminal after running the run script the connecion with the server will be canceled and the engine will not work anymore.
2023-11-20 05:21 PM
any tips for people using windows and facing the same error?
2023-11-21 04:38 PM - last edited on 2023-11-21 11:37 PM by Laszlo Nagy
I have this error as well..What should be done?
2023-11-21 06:44 PM - last edited on 2023-11-21 11:38 PM by Laszlo Nagy
have you tried this button?
2023-11-22 05:22 AM
Yes, I tried. But it comes up with this.
2023-11-22 07:40 AM
same here, tried everything and still same error.
