go
Ancha
since ‎2023-01-10
‎2026-07-01
User Statistics
  • 27 Posts
  • 1 Solutions
  • 28 Likes given
  • 19 Likes received
User activity
https://help.graphisoft.com/AC/28/INT/_AC28_Help/085_MEPDesigner/085_MEPDesigner-11.htmHave anyone actually made this work? The floor plan cut plane does not give me the option to show only the part under the cut plane (as it is described in the Help menu). Operating system ...
Hello, Is there a plan for the Text tool to be improved when it comes to text editing-formating capabilities?These basic settings are not enough in order to use archicad as a presentation tool:Personally missing the "bullets" option, i guess there are more.The goal would be ...
Hello, Shouldn't there be a easy way/option to display Annotation in multiple stories? There are numerous times you need to use the same annotation (texts, contour dimensions, projected element level dimensions from lower stories etc).Maybe something like giving the option t...
Hello, A Mesh issue:Shouldn't there be a way to automatically generate the level dimensions of the contours of a mesh? And to have the option to have them displayed by 0,5m, 1m, 5m, 10m etc. In Revit you just draw a "line" on the mesh and it automatically generates the eleva...
Hello all, It would be super useful to have the choise to manipulate the display order level number of an element from its settings - inserting the number (1-14). Do you agree? Is it something that is happening soon? -A Operating system used: Windows
