Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Ai Server not available
Michiel Neven
I, Have Downloaded the AI Virtualizer, dragged it in to the add-onn folder but receive an AI server not available Error. What am i doing wrong?
25 REPLIES 25
I am facing the same error. You found any solution?
Hi Vikass,
No i have a Macbook pro M1 can not test it on windows..
goncalovalente
I had the same problem.
You have to drag run.sh file into terminal.
Then it will find the server.
What to be done for windows?
Michiel Neven
For all having problem on Mac, I noticed that if you close Terminal after running the run script the connecion with the server will be canceled and the engine will not work anymore.
Joel M
any tips for people using windows and facing the same error?
Ancha
I have this error as well..What should be done?
inesrodrigues
have you tried this button?
Yes, I tried. But it comes up with this.
Joel M
same here, tried everything and still same error.
