Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
problems with installing the AI Engine with AMD Radeon RX 6700 XT
Andrej Berger
When I want to start the AI engine it  says:
Python 3.10.6 (tags/v3.10.6:9c7b4bd, Aug 1 2022, 21:53:49) [MSC v.1932 64 bit (AMD64)]
Version: v1.6.0
Commit hash: 5ef669de080814067961f28357256e8fe27544f4
Launching Web UI with arguments: --api --listen --api-server-stop --no-half-vae --skip-torch-cuda-test
no module 'xformers'. Processing without...
No module 'xformers'. Proceeding without it.
Warning: caught exception 'Found no NVIDIA driver on your system. Please check that you have an NVIDIA GPU and installed a driver from http://www.NVIDIA.com/Download/index.aspx', memory monitor disabled
2023-12-04 07:34:30,355 - ControlNet - INFO - ControlNet v1.1.410
ControlNet preprocessor location: C:\sd.webui\webui\extensions\sd-webui-controlnet\annotator\downloads
2023-12-04 07:34:30,476 - ControlNet - INFO - ControlNet v1.1.410
Loading weights [31e35c80fc] from C:\sd.webui\webui\models\Stable-diffusion\sd_xl_base_1.0.safetensors
ERROR: [Errno 10048] error while attempting to bind on address ('0.0.0.0', 7860): normalerweise darf jede socketadresse (protokoll, netzwerkadresse oder anschluss) nur jeweils einmal verwendet werden
Creating model from config: C:\sd.webui\webui\repositories\generative-models\configs\inference\sd_xl_base.yaml
Running on local URL: http://0.0.0.0:7861
Applying attention optimization: InvokeAI... done.
loading stable diffusion model: RuntimeError
Traceback (most recent call last):
File "threading.py", line 973, in _bootstrap
File "threading.py", line 1016, in _bootstrap_inner
File "threading.py", line 953, in run
File "C:\sd.webui\webui\modules\initialize.py", line 147, in load_model
shared.sd_model # noqa: B018
File "C:\sd.webui\webui\modules\shared_items.py", line 110, in sd_model
return modules.sd_models.model_data.get_sd_model()
File "C:\sd.webui\webui\modules\sd_models.py", line 499, in get_sd_model
load_model()
File "C:\sd.webui\webui\modules\sd_models.py", line 649, in load_model
sd_model.cond_stage_model_empty_prompt = get_empty_cond(sd_model)
File "C:\sd.webui\webui\modules\sd_models.py", line 534, in get_empty_cond
d = sd_model.get_learned_conditioning([""])
File "C:\sd.webui\webui\modules\sd_models_xl.py", line 31, in get_learned_conditioning
c = self.conditioner(sdxl_conds, force_zero_embeddings=['txt'] if force_zero_negative_prompt else [])
File "C:\sd.webui\system\python\lib\site-packages\torch\nn\modules\module.py", line 1501, in _call_impl
return forward_call(*args, **kwargs)
File "C:\sd.webui\webui\repositories\generative-models\sgm\modules\encoders\modules.py", line 141, in forward
emb_out = embedder(batch[embedder.input_key])
File "C:\sd.webui\webui\modules\sd_hijack_clip.py", line 234, in forward
z = self.process_tokens(tokens, multipliers)
File "C:\sd.webui\webui\modules\sd_hijack_clip.py", line 273, in process_tokens
z = self.encode_with_transformers(tokens)
File "C:\sd.webui\webui\modules\sd_hijack_clip.py", line 349, in encode_with_transformers
outputs = self.wrapped.transformer(input_ids=tokens, output_hidden_states=self.wrapped.layer == "hidden")
File "C:\sd.webui\system\python\lib\site-packages\transformers\models\clip\modeling_clip.py", line 822, in forward
return self.text_model(
File "C:\sd.webui\system\python\lib\site-packages\transformers\models\clip\modeling_clip.py", line 740, in forward
encoder_outputs = self.encoder(
File "C:\sd.webui\system\python\lib\site-packages\transformers\models\clip\modeling_clip.py", line 654, in forward
layer_outputs = encoder_layer(
File "C:\sd.webui\system\python\lib\site-packages\transformers\models\clip\modeling_clip.py", line 382, in forward
hidden_states = self.layer_norm1(hidden_states)
File "C:\sd.webui\webui\extensions-builtin\Lora\networks.py", line 474, in network_LayerNorm_forward
return originals.LayerNorm_forward(self, input)
File "C:\sd.webui\system\python\lib\site-packages\torch\nn\modules\normalization.py", line 190, in forward
return F.layer_norm(
File "C:\sd.webui\system\python\lib\site-packages\torch\nn\functional.py", line 2515, in layer_norm
return torch.layer_norm(input, normalized_shape, weight, bias, eps, torch.backends.cudnn.enabled)
RuntimeError: "LayerNormKernelImpl" not implemented for 'Half'
Stable diffusion model failed to load
Exception in thread Thread-18 (load_model):
File "C:\sd.webui\webui\modules\initialize.py", line 153, in load_model
devices.first_time_calculation()
File "C:\sd.webui\webui\modules\devices.py", line 148, in first_time_calculation
linear(x)
File "C:\sd.webui\webui\extensions-builtin\Lora\networks.py", line 429, in network_Linear_forward
return originals.Linear_forward(self, input)
File "C:\sd.webui\system\python\lib\site-packages\torch\nn\modules\linear.py", line 114, in forward
return F.linear(input, self.weight, self.bias)
RuntimeError: "addmm_impl_cpu_" not implemented for 'Half'
To create a public link, set `share=True` in `launch()`.
Startup time: 21.9s (prepare environment: 0.6s, import torch: 5.2s, import gradio: 1.5s, setup paths: 1.3s, initialize shared: 0.5s, other imports: 1.0s, setup codeformer: 0.2s, load scripts: 1.6s, create ui: 0.6s, gradio launch: 9.3s, add APIs: 0.1s).
As I see it, it wants an NVIDIA GPU.
Just a note: Redshift also doens´t work
Anyone had a similar problem?
It is not planned yet, you can install the Add-on on a device that meets the requirements (as a server) and use the Add-on on your device (as a client). For more info please check this post.
Kind regards,
Norbert Kucsma
Technical Support Engineer
4 REPLIES 4
Norbert Kucsma
Hi Planconsort,
Thanks for the question.
The AI Visualizer Add-on is compatible with NVIDIA GPUs only on Windows.
And for Redshift we recommend NVIDIA GPU with CUDA compute capability 7.0 or higher and 10 GB of VRAM or more. (NVIDIA Quadro, Titan, or GeForce RTX GPU for hardware-accelerated ray tracing)
Kind regards,
Norbert Kucsma
So, does this mean I can't use none of those with this hardware at all, or is there a way it might work with AMD GPUs in the future, or a workaround now?
Kind regards,
Norbert Kucsma
Hi, I'm currently using Quadro K5200 for desktop which has CUDA capability of 3.5. Is it this the reason that my AI doesn't start or I could you use this GPU and looking for some other problem?
