2014-07-01 10:28 AM - last edited on 2023-08-01 02:29 PM by Doreena Deng
2014-07-15 05:48 PM
paulk wrote:Hi Paul,
Tibor/Ákos - are you able to provide a response to the issue above pls? I cannot release an AC18 version of my plugin without a resolution to this issue.
Thanks
Paul
2014-07-15 09:43 PM
Are you also linking to the standard libraries?No, I am linking as per the AC17 settings for my project which. Libs included are:
2014-07-16 01:36 AM
2014-07-16 03:34 PM
I managed to get it to link using INCLUDE default libraries, and then excluding stlport_vc7.lib and msvcrt.lib.
Whilst the plugin shows in the Add-On Manager, when selected, the AddOn Info box is blank, and CheckEnvironment, RegisterInterface and Initialize are not being called. So the plugin does not work until AC18.
Again, the plugin is working fine in AC14, 15, 16 an 17.
Paul
2014-07-17 01:17 AM
2014-07-17 10:13 AM
Hi Akos
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL *
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL *
API-MS-WIN-SHUTDOWN-L1-1-1.DLL *
API-MS-WIN-SERVICE-PRIVATE-L1-1-1.DLL *
EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL *
are show as missing, however they also show as missing in AC17.
IESHIMS.DLL also shows as missing, and it appears in the AC17 folder, but copying that DLL into the AC18 folder did not resolve the problem.
Paul
2014-07-19 03:49 PM
2014-07-28 12:46 PM
2014-07-31 02:07 PM
2014-08-09 12:18 AM
Hi Paul,Just seeing if there had been any progress on this issue pls. I sent these files 3 weeks ago, but no response to date.
Could you please send me the current AC17 and AC18 add-on by mail (asomorjai at graphisoft dot com)? I'll try to figure out what's going on.
Best, Akos
