Archicad C++ API
API 26 Documentation
allen-work
Is there anywhere I could view the v26 documentation?
I could not find any commit history the api-devkit project in GitHub.
2 ACCEPTED SOLUTIONS
Joel Buehler
the online v27 documentation works very well with v26. they did not change anything serius since they cant reinvent the wheel all the time. ive never encountered a function that does not work with my v26 plugin when i use the v27 documentation.
https://graphisoft.github.io/archicad-api-devkit/#What_is
in the devkit you allways download the html and msd documentation. but i think they are horrible and do not help.
you can download them here:
https://archicadapi.graphisoft.com/downloads/api-development-kit
hope that helps...
There's no openly accessible way to view the older documentations unfortunately.
If you are a registered developer, you can download the older development kits with the corresponding documentation.
Joel Buehler
hope that helps...
allen-work
Thank you both for the help.
I could find those Goodies function in the old CHM.
