‎2023-10-11
03:33 PM
‎2024-09-16
02:56 PM
Doreena Deng
Is there anywhere I could view the v26 documentation?
I could not find any commit history the api-devkit project in GitHub.
Solved! Go to Solution.
‎2023-10-11 03:42 PM
the online v27 documentation works very well with v26. they did not change anything serius since they cant reinvent the wheel all the time. ive never encountered a function that does not work with my v26 plugin when i use the v27 documentation.
https://graphisoft.github.io/archicad-api-devkit/#What_is
in the devkit you allways download the html and msd documentation. but i think they are horrible and do not help.
you can download them here:
https://archicadapi.graphisoft.com/downloads/api-development-kit
hope that helps...
There's no openly accessible way to view the older documentations unfortunately.
If you are a registered developer, you can download the older development kits with the corresponding documentation.
hope that helps...
‎2023-11-02 04:32 PM
Thank you both for the help.
I could find those Goodies function in the old CHM.
