Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Archicad C++ API
Confusion about starting add-on development
I've registered to the API platform in order to try and develop my own addon.
I am a bit familiar with coding such as HTML and a bit of JavaScript, but my C++ skills are unknown.
I've read through the basic explanations on:
http://archicadapi.graphisoft.com/api-reference
But sadly a lot of it is confusing to me, being a non-programmer.
The first thing that I would like to ask, is how to 'start' my add-on. The instructions say I need an 'MDID' resource in the form of:
'MDID' 32500 "Add-On Identifier" {
        developerID
        localID
But I am not sure how to create this. Is any IDE sufficient? Do I specifically need a Visual Studio platform for this? What file type is this saved as?
Regarding the process in the link:
https://helpcenter.graphisoft.com/technotes/setup/software-technologies/getting-started-with-the-api...
the issue is the "AddOnAdmin". From what I can tell, this is just the add-on manager in ArchiCAD right? When I go to the add-on manager though, I have no option to make a "New Database" as they ask and insert my developer ID and so forth...
So right now I really want to start figuring out specifics of how and what to code for an add-on but I can't figure out the initial steps to start doing this.
I'm also a bit unclear about which file types the code needs to be saved as in general and if there is a specific folder structure within my addon folder that I need to respect.
I've marked all the questions in Bold and would be happy if someone knows how to answer any of them
Thank you!
29 REPLIES 29
If you are not yet a solid programmer and an experienced ARCHICAD user, the ARCHICAD API is not the place to learn. You should be able to answer most of your bold questions yourself when you are ready to be here.
Take an in-person or online class and become proficient developing simple apps in C++ and Visual Studio if you are using Windows or XCode if you are on a Mac. Then consider layering the complexity of AC development on those basic skills later.
Good luck!
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I have a few questions without opting in on the API website. I found it quite closed without any answers.
Do we have control over Archicad itself or only the model database? Can I start archicad, close the warning windows, start publishing without any user interaction?
How about C#? For revit we are using it and I have some experience with it but not with C++. Although it is kind of similR I'm not really willing to jump into it for smaller tasks.
My understanding from some time back - Ralph, Akos or someone can clarify:
There is no interface to fully control ArchiCAD by an independent process. No, you cannot close warning windows. Yes, an add-on can invoke Publisher on a publish set...but only after invoking the add-on. (Example in the Navigator-Test sample add-on in the devkit.) Typical add-ons are invoked by the user explicitly (menu or shortcut keys) and have access to the databases. Add-ons can be associated with building elements and can be invoked when a user touches/modifies those elements.
I think it would require way more work to make everything work with C# (if even possible) than it would to learn C++. See this topic:
http://archicad-talk.graphisoft.com/viewtopic.php?t=55976
For AC21 API development, the following are the environments for which all tools are designed (from the API docs):
Windows: Microsoft Visual C++ 2015 Update 3 installed. Only the 64-bit architecture is supported
macOS: Xcode 7+ (Xcode 8+ recommended)
So this is the reason there are no great tools like Clarity for Revit in the market for Archicad.
Automation is the way to go and controlling your software automated is a huge potential. Think about scheduled exports, scheduled archiving ect. that require no manpower.
I would really looking forward to have something like this, also to prepare it to myself.
Ralph Wessel
Mentor
Karl has done a good job of answering your questions. Just to expand a bit:
- The API is primarily about interacting with the user and doing things to the project model. It's also possible to interact with the host OS, do network-based operations and work with files. You can interact with other processes and control ARCHICAD to some extent, but it relies more on work-arounds than explicit API support. I've have written add-ons to support automation via external applications, but it felt like swimming against the tide.
- Use C++ for ARCHICAD development. Direct use of C# isn't an option. Karl has correctly identified suitable development software.
Ralph Wessel BArch
Can anyone help me? I installed a development kit 21 and launched Geometry (Geometry_Test) add on from the samples. It was built successfully and I could even debug it but there was no result after launching it. As far as I got it there should be created a rectangular and then it should be transformed. Am I wright?
Ralph Wessel
Mentor
Have you tried running the add-on without an ARCHICAD license? The examples do not specify a developer code and will only work in demo mode.
Ralph Wessel BArch
Thanks for your reply. Yes, installed the Archicad 21 in trial mode and registered as a developer. Has I got it right I should have a paid license in order to test add ons?
Ralph Wessel
Mentor
No, you don't need a paid ARCHICAD license to test the add-ons.
Ralph Wessel BArch
