ā2017-10-11
07:14 PM
ā2023-07-12
08:39 PM
Doreena Deng
'MDID' 32500 "Add-On Identifier" {
developerID
localID
But I am not sure how to create this. Is any IDE sufficient? Do I specifically need a Visual Studio platform for this? What file type is this saved as?ā2018-07-30 07:29 PM
Ralph wrote:It's really odd for me, that the provided example does nothing. Is there any description about "Geometry (Geometry_Test)" sample? Or any other recommendations
No, you don't need a paid ARCHICAD license to test the add-ons.
ā2018-07-31 10:50 AM
ā2018-07-31 11:00 AM
Ralph wrote:Yes, I can see it. And I click it to start debugging
When the add-on is built and present in the Add-Ons folder when ARCHICAD is launched, do you see a menu itemTest > Geometry Functions > Rotate Lines (place a rectangle)in the main menu bar?
ā2018-07-31 11:12 AM
ā2018-07-31 11:25 AM
Ralph wrote:Yes it works perfectly, thank you Ralph a lot.
When you use the menu item for this add-on, check if the lines are placed on another storey, e.g. one above the ground floor. I find the lines appearing on the first floor.
ā2018-07-31 11:38 AM
ā2018-07-31 11:50 AM
Ralph wrote:Could you please advise me how to create something similar to point cloud. I want to generate points in my add on and place them on scene. I know I can import point clouds of some formats, how can I create point cloud in add on?
No, I don't think it's possible to interact with ARCHICAD's 3D mode like that. You can do that in a custom window, but I doubt that's what you want.
How about using GDL objects placed in the model to achieve what you want?
ā2018-07-31 12:05 PM
ā2018-07-31 12:09 PM
Ralph wrote:Thanks, I'll look into this functionality
You could do that with GDL objects.
ā2018-07-31 03:30 PM
Ralph wrote:I have some questions about GDL objects:
