Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Archicad C++ API
Creating a Clickable Table in UI
Amit Tiwari
I want to create such an UI Where a table is displayed and the user is able to make selections by clicking on any row in the table.
Hi Amit,
To achieve what you are after you will probably need to research the List Box dialogue item type - SingleSelList / MultiSelList and all the associated DGList functions.
You will also need to check out OnTab items and DGListSetDialItemOnTabField. Using this you can use many different dialogue item types - not just text / icons.
Danny
6 REPLIES 6
Amit Tiwari
@Amit Tiwari ,
There is no need to tag Ralph (or anyone else) personally unless you need to get their specific attention to a post.
If it is just a general question, it is open for anyone to answer.
I am sure Ralph browses this forum when he has the time and if he feels inclined to answer, I am sure he will.
Hi Amit,
Danny
Ralph Wessel
Mentor
In addition to what Danny wrote, take a look at the example project "DG_Test", specifically code including "DG::SingleSelListBox". The OwnerDrawnListBoxPalette class is one case.
Ralph Wessel BArch
Software Engineer Speckle Systems
Thank you Danny, I shall research these right away.
Thank you Ralph. I will go through this Example Right away.
