Amit Tiwari
Creating a Clickable Table in UI
I want to create such an UI Where a table is displayed and the user is able to make selections by clicking on any row in the table.
1 Solution
Hi Amit,
To achieve what you are after you will probably need to research the List Box dialogue item type - SingleSelList / MultiSelList and all the associated DGList functions.
You will also need to check out OnTab items and DGListSetDialItemOnTabField. Using this you can use many different dialogue item types - not just text / icons.
Danny
Go to post
6 Replies 6
Amit Tiwari
@Amit Tiwari ,
There is no need to tag Ralph (or anyone else) personally unless you need to get their specific attention to a post.
If it is just a general question, it is open for anyone to answer.
I am sure Ralph browses this forum when he has the time and if he feels inclined to answer, I am sure he will.
Hi Amit,
Danny
In addition to what Danny wrote, take a look at the example project "DG_Test", specifically code including "DG::SingleSelListBox". The OwnerDrawnListBoxPalette class is one case.
Ralph Wessel BArch
Central Innovation
Amit Tiwari
Thank you Danny, I shall research these right away.
Amit Tiwari
Thank you Ralph. I will go through this Example Right away.
