‎2023-11-07
10:45 AM
‎2024-09-17
01:20 PM
Doreena Deng
Hello all,
How can we import a custom material /texture for walls and use the custom material through Add-On code? Is it possible to simply provide the URL of the texture?
Update -> Have added a screen shot of the custom image import for materials that I mentioned above.
Thank you,
Kency
Solved! Go to Solution.
‎2023-11-07 08:10 PM
You can do it with the API, but you need to implement a couple of steps to achieve the final result:
‎2023-11-08 07:33 AM
No out of the box solution, but you may check these example add-ons in the Development Kit:
‎2023-11-08 05:41 AM
Thank you @Viktor Kovacs .
1. Is there any folder within the downloaded ArchiCAD application? Or the only way to import is through the ArchiCAD UI?
2 and 3. Any example that you know of is available for the same in the DevKit?
