ā2021-09-26
04:39 PM
ā2024-09-09
11:24 AM
Doreena Deng
Hi all!
I'm new to GDL and I'm attempting to do a custom label that is able to identify which type of element is being labeled and then is able to put out its surface information, according to the type identified.
For example: if the labeled element is a floor, it puts out the "Top surface" of the element (Following eventual surface overrides). If it is a ceiling, puts out the "Bottom surface". If it's a wall, it puts out the "Inside finish surface" or the "Outside".
My questions are the following:
1 - How to 'Request' those surface names of the labeled object to use in the label object.
2 - How to condition the surface name used according to the type of element. (I'll use the same label to label walls, slabs, beams, so on)
3 - How to add a parameter to the label to choose Internal/External finish (In case it is a wall, or a beam)
4 - Would it be possible to identify if the reference line of the wall is internal/external so I can "position" my label to the correct side of the wall? (Auto-adapt according to which side finish I chose to label)
I don't intend to use Archicad Properties for that, because I can't use "Hybrid" element types. It fails to return values if I use multiple element types at the same property. Also, the label symbol should have a custom shape depending on the type of element being labeled, so I'm heading to GDL to have that freedom.
That's it. If anyone can show me directions to solve any of those questions, I'd be very thankful š
Solved! Go to Solution.
ā2021-09-30 03:10 PM
Thanks David! I did change the 2nd parameter to 3 but it didn't alter the fill.
Still hollow.. (The label is already at the top in the view order)
And thanks for the tip regarding the signature, I'll adjust it soon š
ā2021-10-01 02:54 AM
Have you SET the fill before the POLY2 command (SET FILL ...)?
You need to tell it what fill you intend to use.
If you have set an 'Empty' fill, the background pen will need to be coloured.
If you have set a 'Solid' fill, the foreground pen will determine the colour.
If you have set a 'Hatched' fill, you will need to set both foreground and background pens to the same colour.
ā2021-10-01 04:49 PM
I was missing that! š
Now it worked! Thanks
ā2022-06-07 10:38 AM
cann you share the label?
ā2022-06-07 01:31 PM
Hi JanisL
It was developed further since this topic was created. If you're interested I could tinker it to your use, you may contact me (pedro@ideia1.com.br)
