Miha Nahtigal
Get element's ID
Hi everyone.
I am looking for a API function to get element's (object's, slab's,...) ID - the field in the "ID and properties" section of elements palette. Can not find it in the documentation.
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
1 Solution
kovacsv
It can be accessed with the ACAPI_Database function using the APIDb_GetElementInfoStringID id: https://archicadapi.graphisoft.com/documentation/apidb_getelementinfostringid
Go to post
4 Replies 4
kovacsv
Miha Nahtigal
Thank you for your prompt and accurate answer.
LeeJaeYoung
I am trying to put an id while creating a beam.
I think it will be easier to understand if there is a code.
Which code in the example can I understand?
AC27 on window 11
LeeJaeYoung
err = ACAPI_Database(APIDb_ChangeElementInfoStringID, &element.header.guid, &na);
ACAPI_Database not found in archicad 27 api
There is also no content in ACAPinc.h.
What should I study?
And I don't have apidevkit.chm, where should I search for it?
AC27 on window 11
