2023-07-26 04:53 PM
As shown in picture, is there any suggestion of how to detect right click event then create select able menu with API functions?
2023-07-29 01:51 PM - edited 2023-07-29 01:53 PM
this one seems to be helpful:
2023-08-08 11:30 AM - edited 2023-08-09 09:01 AM
You can detect right mouse click by implementing/overriding the
virtual void ListBoxContextMenuRequested (const ListBoxContextMenuEvent& ev, bool* processed);
virtual function of the ListboxObserver.
And you can create a custom context menu like this:
void OpenContextMenu (const DG::NativePoint& pos)
const ULong CmdId1 = 1001;
const ULong CmdId2 = 1002;
const ULong CmdId3 = 1003;
DG::Command cmd1 (CmdId1, 0, 0);
DG::Command cmd2 (CmdId2, 0, 0);
DG::Command cmd3 (CmdId3, 0, 0);
DG::CommandDescriptor cmddesc1(cmd1, GS::UniString ("Command 1"));
DG::CommandDescriptor cmddesc2(cmd2, GS::UniString ("Command 2"));
DG::CommandDescriptor cmddesc3(cmd3, GS::UniString ("Command 3"));
GS::UniString menuNameStr ("ContextMenu");
DG::Menu* menu = new DG::Menu (menuNameStr);
if (menu == nullptr)
return;
menu->AddMenuItem (DG::MenuSimpleItem (CmdId1));
menu->AddMenuItem (DG::MenuSimpleItem (CmdId2));
menu->AddMenuItem (DG::MenuSimpleItem (CmdId3));
DG::ContextMenu* contextMenu = new DG::ContextMenu (menuNameStr, menuNameStr, menu);
if (contextMenu == nullptr) {
delete menu;
return;
DG::CommandTable enabledCommands;
enabledCommands.Put (CmdId1, &cmddesc1);
enabledCommands.Put (CmdId2, &cmddesc2);
enabledCommands.Put (CmdId3, &cmddesc3);
contextMenu->SetEnabledCommands (enabledCommands);
Int32 commandId = 0;
DG::CommandEvent* commandEvent = contextMenu->Display (pos);
if (commandEvent != nullptr)
commandId = commandEvent->GetCommand ().GetCommandId ();
delete commandEvent;
delete contextMenu;
delete menu;
switch (commandId) {
case CmdId1:
case CmdId2:
case CmdId3:
break;
default:
break;
Or you can also create a popup-like dialog with a listbox or any other controls inside. The popup like dialog is closed on a mouseclick outside of the dialog area. You can set the popup-like style with the DG::Dialog::SetPopupStyle() member function. Popup dialogs must not have caption and sizeable flag. See the following example:
'GDLG' SAMPLE_POPUP_DLG_ID Modal | noFrame | noCaption | noGrow 0 0 100 100 "" {
/* [ 1] */ LeftText 5 5 90 23 SmallPlain vCenter "Text"
'DLGH' SAMPLE_POPUP_DLG_ID DLG_SAMPLE_POPUP {
1 "" LeftText_0
class SamplePopupDialog: public DG::ModalDialog,
public DG::PanelObserver
enum {
LeftTextId = 1
DG::LeftText text;
const DG::NativeRect& openButtonScreenRect;
public:
SamplePopupDialog(const DG::NativeRect& openButtonScreenRect_);
~SamplePopupDialog();
virtual void PanelOpened (const DG::PanelOpenEvent& ev) override;
SamplePopupDialog::SamplePopupDialog (const DG::NativeRect& dialogOpeningButtonScreenRect_, ...):
DG::ModalDialog (resModule, SAMPLE_POPUP_DLG_ID, resModule),
text (GetReference (), LeftTextId),
dialogOpeningButtonScreenRect (dialogOpeningButtonScreenRect_)
SetPopupStyle ();
Attach (*this);
SamplePopupDialog::~SamplePopupDialog ()
Detach (*this);
void SamplePopupDialog::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
DG::Utils::PlaceDialogNextToNativeRect (*this, dialogOpeningButtonScreenRect, DG::Utils::RightCenter);
