Archicad C++ API
SOLVED!
I want to put the ID value in C++ while creating Beam.
LeeJaeYoung
I want to put the id value in C++ while creating Beam.
What should I do?
I created it by looking at the create element_test code.
What can I study?
I'm a beginner who can understand if you give me the code. ^^
1. Solved: Get element's ID - Graphisoft Community
AC27 on window 11
1 ACCEPTED SOLUTION
Solution
ReignBough
Is this what you need: ACAPI_Database(APIDb_ChangeElementInfoStringID, ...)?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
9 REPLIES 9
Solution
ReignBough
~ReignBough~
LeeJaeYoung
GSErrCode ACAPI_Database(APIDb_ChangeElementInfoStringID,element.header.guid, "ABC111");
err = ACAPI_Element_Create(&element, &memo);
if (err != NoError) {
ACAPI_WriteReport("ACAPI_Element_Create (Beam) has failed with error code %ld!", true, err);
I'm a beginner so I don't understand because I don't have the code.
I need a code that can change the ID value.
1. I'm curious whether it's before or after creation and why the error occurs. ^^
1.
err = ACAPI_Database(APIDb_ChangeElementInfoStringID, &element.header.guid, "xx");
return;
2.  archicad is dead
return;
AC27 on window 11
Miha Nahtigal
You need to call your routines inside ACAPI_CallUndoableCommand()  block.
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
 err = ACAPI_CallUndoableCommand("Create Beam",
[&]() -> GSErrCode {
return ACAPI_Database(APIDb_ChangeElementInfoStringID, &element.header.guid, "xx");
The id value did not change to "XX".
return ACAPI_Element_Create(&element, &memo);
The following error occurs.
AC27 on window 11
LeeJaeYoung
thank you so much. ^^
I understand now. ^^
AC27 on window 11
err = ACAPI_Database(APIDb_ChangeElementInfoStringID, &element.header.guid, &na);
ACAPI_Database not found in archicad 27 api
There is also no content in ACAPinc.h.
What should I study?
And I don't have apidevkit.chm, where should I search for it?
AC27 on window 11
Check migration documentation and ACAPI_MigrationHeader.hpp inside Support\Inc folder
Use  ACAPI_Element_ChangeElementInfoString() instead of ACAPI_Database(APIDb_ChangeElementInfoStringID...)
Thank you for your advice.^^
Have a happy weekend.
AC27 on window 11
ReignBough
When functions/structures were changed in SDK (and we used them), we put them in a function wrapper to call the proper functions/structure member. Especially, when we support the lower versions of ArchiCAD.
Example:
GSErrCode Db_ChangeElementInfoString(API_Guid* guid, GS::UniString* id)
if (ARCHICAD_VER >= 27)
return ACAPI_Element_ChangeElementInfoString(guid, id); else if (ARCHICAD_VER < 27 && ARCHICAD_VER >= 23) return ACAPI_Database(APIDb_ChangeElementInfoStringID, guid, id); else //if (ARCHICAD_VER < 23)
return APIERR_NOTSUPPORTED; //return NoError; }
void Elem_SetElemType(API_Elemennt& elem, API_ElemTypeID typeId)
if (ARCHICAD_VER >= 26)
elem.header.type.typeID = typeID;
else //if (ARCHICAD_VER < 26)
elem.header.typeId = typeID;
 ARCHICAD_VER is then defined in Project Property's Preprocessor.
~ReignBough~
