Is it possible to create a profile column wall with api c++?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-08-08 05:17 AM
If possible, which sample file should I study?
You told me that wall composite files are possible.
So, I'm curious about whether a wall column beam profile is possible, so I'm asking.
If possible, I would appreciate it if you could let me know what part I need to study.
Solved! Go to Solution.
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-08-09 07:55 AM
Ok, I see, you would like to create a Profile Attribute. It's a bit more tricky, please check the Attribute_Test example Add-On, and see the Do_CreateProfile function for an example.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-08-08 07:18 AM
Here is a full example of creating a composite wall:
ACAPI_CallUndoableCommand (undoStepName, [&]() -> GSErrCode {
// Get the default settings of the Wall element. Every parameter you doesn't specify
// will come from the default element.
API_Element element = {};
element.header.type = API_ElemType (API_WallID);
if (ACAPI_Element_GetDefaults (&element, nullptr) != NoError) {
return Error;
// Set the Wall to be Composite type, and set the Composite index you would like
// the Wall to have. The Composite index must be determined by your own logic.
element.wall.modelElemStructureType = API_CompositeStructure;
element.wall.composite = compositeIndex;
// Set the begin and end point of the Wall's geometry.
element.wall.begC = { 0.0, 0.0 };
element.wall.endC = { 1.0, 0.0 };
// Create the element.
if (ACAPI_Element_Create (&element, nullptr) != NoError) {
return Error;
return NoError;
.To create a profiled one, change these lines.
element.wall.modelElemStructureType = API_ProfileStructure;
element.wall.composite = profileIndex;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-08-08 02:13 PM
thank you ^^
sorry.
I've been asking to make a STYLE.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-08-09 07:55 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-08-09 12:29 PM
thank you
After studying, I will ask you another question. ^^
