Archicad C++ API
Is it possible to create a profile column wall with api c++?
LeeJaeYoung
If possible, which sample file should I study?
You told me that wall composite files are possible.
So, I'm curious about whether a wall column beam profile is possible, so I'm asking.
If possible, I would appreciate it if you could let me know what part I need to study.
AC27 on window 11
Viktor Kovacs
Ok, I see, you would like to create a Profile Attribute. It's a bit more tricky, please check the Attribute_Test example Add-On, and see the Do_CreateProfile function for an example.
4 REPLIES 4
Viktor Kovacs
Here is a full example of creating a composite wall:
ACAPI_CallUndoableCommand (undoStepName, [&]() -> GSErrCode {
    // Get the default settings of the Wall element. Every parameter you doesn't specify
    // will come from the default element.
    API_Element element = {};
    element.header.type = API_ElemType (API_WallID);
    if (ACAPI_Element_GetDefaults (&element, nullptr) != NoError) {
        return Error;
    // Set the Wall to be Composite type, and set the Composite index you would like
    // the Wall to have. The Composite index must be determined by your own logic.
    element.wall.modelElemStructureType = API_CompositeStructure;
    element.wall.composite = compositeIndex;
    // Set the begin and end point of the Wall's geometry.
    element.wall.begC = { 0.0, 0.0 };
    element.wall.endC = { 1.0, 0.0 };
    // Create the element.
    if (ACAPI_Element_Create (&element, nullptr) != NoError) {
        return Error;
    return NoError;
.To create a profiled one, change these lines.
        element.wall.modelElemStructureType = API_ProfileStructure;
        element.wall.composite = profileIndex;
thank you ^^
sorry.
I've been asking to make a STYLE.
AC27 on window 11
Viktor Kovacs
thank you
After studying, I will ask you another question. ^^
AC27 on window 11
